Hi all
wanting to know if any1 has any idea Wat is up with my goddy , ???
1st of all i recently had problems with my turbos e.g white smoke pouring out exhaust and oil all threw my inter cooler pipes, i went to c.n.j motor sport up in Underwood and they said the turbos r fine but i have since found out that they are not fine and i have done a oil seal ..... anyway i have just gathered up enuf money to send it to Godzilla motor sport as i have heard good things about them can any1 confirm that ?? its going in for new turbos and tune etc ..... now here's the big but :) i started the car up which was running fine even tho turbos r no good and it seems to be now dropping a cylinder or 2 does any1 have any ideas as to y its running like that now when it wasn't even after the turbos went ages ago????
any help would be great thanks
https://www.sau.com.au/forums/topic/328000-running-like-shit/
You said you had oil in your intercooler pipes, my guess would be that the oil in the intake has fouled up your spark plugs. possible quick fix is to pull ur plugs out and give them a clean
Thanks heaps for that might thought that might be the problem I wil get them to do it at shop..do u know anything bout Godzilla Motorsport??
Ive never been there but i have heard some very good things about them , and seen some very tough engines come out of there
sweet as hopefully they will be building one more :yes: thanks for ur help
Hey me again
found out today its my bottom end that needs rebuilding so wanting some advice as to wat parts to throw back in as i want a good strong engine thats good for 650hp-700hp, just trying to suss out how much parts for bottom end would roughley be before i go buying up .....
any help please ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
