  • Replies 72
Will be driving through there later today, will look again. I've seen those beige-looking things before, they have been there for ages. If it's something else people are talking about, then it's something to look into for sure!
Dought they would. More work for them
For who? What's work?
If you're talking about paperwork for police... you're probs right, the state government would never take the chance to raise some more revenue and overwork their police force. Oh wait :rofl:
Next time someone drive through the tunnel, can you pull over on the emergency stop lanes & take a photo please? ;)
Not sure If I'm even looking for the correct things at the correct places...
First of all, how can you have 2 first of alls?
Second of all these cameras were installed by the security guys who work for my company :D :D. I can ask them the details of the "monitoring" but from what the cameras are they do not have speed recording in them.
P.S. They start out as white cameras and are sprayed black.
P.P.S. They are always heading down to sort out issues with the system. 2 of them were there until 2am a on Sunday morning I think.
Thought I'd update you guys again (although I don't think anyone saw my last post, hmm). These cameras are situated above a little yellow plaque on the side of the tunnel according to the security guys at my work. There are about 25 cameras in each tunnel and SPEED RECORDING IS FUNCTIONING. The guys said they can watch the speeds of cars but I don't think any sort of fine is being issued yet.
Also 2 permanently mounted speed cameras will be mounted at the exit of each tunnel. This is only the plan at the moment, it could change.
Man, we really need to find someone who knows the people that work with these things inside the tunnel. They might be able to tell the speed of the traffic inside there but can't use it as evidence, who knows..
Could be that they have no intentions of calibrating/servicing the speed devices in the tunnel regularly enough to be used as evidence. Like the same deal with multanova cameras, police car speedos etc having to be regularly calibrated.
But a far more realistic theory would be - Maybe the big shots running the tunnel have gate/screamer pipes on their cars and enjoy a bit of speed/noise through the tunnel themselves :)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
