I was just curious bout the jap language. Is it easy to learn or what? I've decided to go to tafe and always wanted to learn a language and thought japanese would be a good one to learn.
So will it be hard or easy or inbetween i know it would mainly depend on me and weather i will pick it up or not but any help is good.
https://www.sau.com.au/forums/topic/32845-language/
Just remember Ben, it's all dependent on your attitude... if you *really* believe you'll benifit personally by learning Japanese, and you won't be afraid to concienciously make mistakes (because you don't know how to say it exactly in Japanese, but want to express yourself), then you're on the right track. My 2c...
https://www.sau.com.au/forums/topic/32845-language/#findComment-659222
...but Japanese is damn difficult sometimes. Kanji for me is the most challenging. Of course that means reading is difficult too, but when you do learn something useful, it's soooooooo satisfying.
https://www.sau.com.au/forums/topic/32845-language/#findComment-659510
Totally, I am 100% with Rezz. I lived in Japan for a while and learnt Nihongo pretty quickly, but that is because I was tough on myself and only hung out with native Japanese speakers and learnt Kanji everyday. Easy to get in the foreigner groove and loose focus, but when you get it going, it is really awesome to be drinking and having a blast with locals.
Be persistent!!!
my 2c
https://www.sau.com.au/forums/topic/32845-language/#findComment-659742
pricy? im married to a japanese girl and the most weve spent so fay is on my car and a plasma tv.....    the wedding ceremony is heaps but you dont have to have one.
Pricy..I mean not only money..I have been married one for 11 years now, I paid my freedom for that..so..it's pricy.. :Oops:
https://www.sau.com.au/forums/topic/32845-language/#findComment-672532
yep im learning japanese now in yr 11, i love it cause i enjoy it if u dont u've got f**k all chance . its not a nesessity to learn kanji. you can spend a life time learnin it. learn hiragana. 46 basic characters super easy.i also plan to go to japan after hsc so can any body suggest the major cities for car activity, underground and workshop.
https://www.sau.com.au/forums/topic/32845-language/#findComment-689903
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
