Sard 550cc injectors for rb25det (with collars), high impedance, part number 63500 - $600 posted to you.
Bought from this guy:
http://www.skylinesaustralia.com/forums/Gt...R3-t319684.html
Weren't quite what I was expecting. He obviously had never installed them in a rail, as they had to be modified to fit. I've had them cleaned and tested, work fine.
I have injector plugs that I'd be prepared to swap with you as I've gone back to stock RB25DET injectors and they are a bit different.
Thanks,
Matt
https://www.sau.com.au/forums/topic/329118-sard-550cc-injectors-suit-rb25det/
Sorry guys, another reason why I should not blindly copy his stuff.
Part number are Denso 195500-2240 which according to Witchhunter are 550cc side feed high impedance.
Sard part number is 63508.
As per
And these are actual photos of one of mine. All part numbers match.
And
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
