Item: 1994 Nissan S14/200sx with evil eye conversion, 207000km on the chassis, 25000km on forged motor, 5 speed manual, rego until March 2011
Specs as follows:
Engine/Electronics:
Fully forged SR20 bottom end (has 25000km on it since install - CP pistons with 86.5 bore, Eagle rods, ARP headstuds, ARP mainstuds, crankshaft machined and balanced)
HKS metal head gasket 1.2mm
Trust rocker arm stopper
brand new oil pump
brand new water pump
brand new timing chain and tensioner
diff and gearbox fluids changed 10000km ago
high flowed T28 turbo (tuned at 19psi)
HKS SSQ BOV
550cc injectors
Apexi AVC-r electronic boost controller
Apexi power fc j-detro with hand controller and air flow meter removed
direct intake pipe from K&N pod filter to the turbo
Coolingpro aluminium radiator
Hi Octane radiator air guide
Apexi 1.3kpa radiator cap
heavy duty racing grade blue radiator hoses
Hybrid front mount intercooler
Hybrid vacuum distributor
blue racing grade vacuum hosing (with spare length)
Apexi aluminium induction box for pod filter
Walbro 500hp fuel pump
mandrel bend 3 inch exhaust system from the turbo back with sports cat converter and 4 inch X-Force cannon (with silencer aswell if required)
Tien Super Street suspension
adjustable caster bushes
full adjustable camber kit
all front bushes replaced with new urethane bushes
Cusco front and rear strut braces
(have dyno sheet for 215.9rwkw)
Interior:
Sparco X-Fast gear knob
Sparco steering wheel
leather “Silvia” embossed gear boot
2 x Monxa SP12 reclinable sports seats
“Silvia” embossed vinal rear seat cover (black and light blue)
colour coded dash (same colour as exterior - centre console lid, ignition barrel surround, dash cluster surround, gearbox lid, stereo surround, air conditioner surround)
Exterior:
Genuine Uras S14 Type S full kit (front bar, rear bar side skirts) - imported myself from Japan
Uras 25mm wide vented front guards
full respray in Opal (blue base layer with purple and green pearl)
Lenso D1r 5 spoke rims - black painted centre with polished lip (275/17/40 rear and 245/17/40 front – 98% Sumitomo rubber)
5Zigen lock nuts made of aircraft alloy
S15 “lightening bolt” badge on bonnet
personalized number plates (black with metallic silver writing)
smoked tail lights with garnish, smoked front bar blinker, smoked front corner blinker (have original tail lights and garnish aswell if required)
shaved ariel hole and spoiler holes
30% tinted windows
Stereo:
JVC KW-AVX810 double din dvd player (dvd-r, dvd+r, cd-r, mp3, avi, divx, usb input, SD memory card reader, optional input for reversing camera, has bluetooth with module for most motorola phones)
pair of alpine 6½ inch 3 way splits with cross overs (front doors)
pair of alpine 6½ inch 2 ways (rear parcel shelf)
pair of Clarion 10 inch subwoofers
Clarion V-Net 450 amp
have receipts for almost everything since I purchased the car in 2007
Reason for Selling: I'm currently overseas so instead of having it sit there I'd like to see someone else enjoy it
Contact Details: The vehicle is with my parents so there are a few options...my mother's mobile number is 0412696751 or you can email me at [email protected] or simply PM me through here and I'll get back to you...
Price: $13 999 ono (No Swaps)
Recent Pictures:
Hello Friendly Skyline Driver,
I was looking at your car and am quite intrested, it just seems a daunting that there is evil eyes in this car as you said. Why did you put them in? And what makes them evil? Are you sure theyre not regular eyes?
Thankyou.
vertex kits are common...i wanted something out of the ordinary...and i will find the right person to take this off my hands
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
