hey all, im new to this site & skylines
i recently bought a R33 GTS4 paid about 3500 for it.
i was just wondering is there a way to disable the attesa system?
and then simply just plug it in again?
or is this only the R32's?
any feedback would be greatly appreciated:)
thanks
https://www.sau.com.au/forums/topic/329610-gts-4/
you cannot just pull out a fuse like in the 32's. this is because their system was electrical and the 33's are hydrological.
You can drain the resovior in the boot but the safest thing to do is take out the front drive shaft.
BTW, how did you manage a 33 gts4 for 3.5k? is it damaged?
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5356095
The caniser in the boot runs down to the actuator on the O\S\R of the car, it pumps fluids to the transfer case and when the slip light is activated it then runs too the rear diff and is pumped around there aswell, then back too the canister. It does this because it is a high pressured pump that activates clutch packs in the transfer case, this is how the attesa system works. Do not take the fluid out of the clutch packs with be distroid and you will have to spend a lot of money and all the parts with be EX jap.
The fluid is a ATF fluid, at nissan we sell nissan Matic D which is what they used stock.
You can take the front propeller shaft out but thats it.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357381
how would i pull out the shafts? just pull them out
your only taking out the front shaft.
It is located under the car more towards the drivers side next to the gear box area.
there are four bolts that attach it to the car, they are in pricks of a position to get off...
the thing i do is, move one bolt at a time to the best position possible for you to reach by rolling the car, undo it and take it off, roll your car a little back or forward so the next bolt is in the same position and repeat.
when you get good at it, you can have it off in 10-15 mins if that....
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5357421
As said before.
You can only disconnect the 4wd system in the R32's electronically.
In the 33 and 34 you must remove the front drive shaft.
This is the shaft from your transferbox (the thing hanging off the drivers side of the gearbox) going up to the front diff.
https://www.sau.com.au/forums/topic/329610-gts-4/#findComment-5359314
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
