Hi guys, i'm clearing out my hoarded items that either came of my car or never made it onto the car....
I think i have a problem. Here's the items, photos are below.
-Prices are negotiable to a degree.
-Postage price is non negotiable, and is on top of the agreed price. I do not make money of postage.
If i charge an extra few $ on top of postage, its coz i have to find a box, pack it up and wait 40
minutes in my 55 min lunch break to send your parcel.
1 Surge tank to suit 2 bosch 044 pumps. has 2 x -8 JIC fittings to pumps,
2 x -8 on the side and 1 x -8 on top Price - $160
2 Foam Filled Plastic Fuel Tank, never used, conforms to CAMS regs i have been told.
has 2 x -8 JIC fittings for pumps and 1 x -6 for return on the top. - $200
3 6 standard RB25 side feed injectors out of car for about a year - $80
4 Rb25 manual series 2 ECU, will run S1 also - $50
5 Z32 Afm - unknown condition, didnt know i had it - $100
6 2 x sets of Rb25 Cams with cam gears and Solenoids - $75 a set
7 CAS for rb25, again didnt know i had it, comes with bracket, unknown condition - $75
8 RB25 Hydraulic lifters, set of 24, all good condition,
have sat in oil bath for close to 2 years.
didnt make noise when taken out of head - $50
9 Set of good condition std rb25 pistons, no marks on tops of pistons,no rings,
free conrods, conrods are rusted. $50
10 Rb30 crank - has been micropolished, kept this one as a spare in case mine
shit itself, hasnt happened yet, wont need it. $100
11 Chromed RB25 Intake manifold top. removed for plazmaman setup. excellent condition $50
12 3inch dump and frontpipe to suit lowmount KKR430 or kkr480 turbo,
partially heatwrapped. V band with clamp. $200
13 KKR style turbo HOUSINGS. front rear and CHRA. no shaft or blades.
bought as spare, never needed, sold turbo, buyer didnt want spares.
Comes with V band adapter. $100 for all of them
14 Compressor housing off a garret 35/40. 0.7A/R, with anti surge holes drilled.
decided against hacking it up to fit my engine bay. $200
15 Greddy Y-pipe with BOV return welded off. used for 3 dyno runs and
then changed to 1 big 4 inch filter. Was sitting around a bit i didnt wana sell it. $250
16 2 x Genuine Greddy Airinx air filters. 80mm tyres, never used. got wrong colour,
never returned as i bought from USA.both for $170 or $90 each
17 Rb25 O2 sensor. dont use it anymore. $20
18 RB25 VCT sensor, pulled off my head when i did the 30 conversion $50
19 Power FC Boost control solenoid, changed ECU's, was on a RB25 power fc.
only just got this back from the workshop, ecu sold a while ago - $300
OK, i think thats it for now. will add more stuff at a later date. Pictures Below
Contact me on 0401689894 via SMS, or PM (sms will get fastest reply)
Offers welcome
Edited by Gothik33
  • 1 year later...
ANNUAL BUMP :domokun: :domokun: :domokun:
JUST BACK FROM OVERSEAS AND FOLLOWING ITEMS ARE STILL LEFT
4 RB25 manual series 2 ECU, will run S1 also - $50
Comes with V band adapter. $100 for all of them $50
16 2 x Genuine Greddy Airinx air filters. 80mm intake diameter, never used. got wrong colour,
never returned as i bought from USA.both for $170 or $90 each $150 both, $75 each
17 RB25 O2 sensor. dont use it anymore. $20 $15
again, sms for inquiry about post, postage price based on location, 0401689894
Edited by Gothik33
I'll take the O2 sensor.
Brisbane 4073
PM me with the best way to pay you.
Cheers
SImon
    • I have no hard data to report, but I have to say, having driven it to work and back all week, mostly on wet roads (and therefore mostly not able to contemplate anything too outrageous anywhere)..... it is real good. I turned the boost controller on, with duty cycle set to 10% (which may not be enough to actually increase the boost), and the start boost set to 15 psi. That should keep the gate unpressurised until at least 15 psi. And rolling at 80 in 5th, which is <2k rpm, going to WOT sees the MAP go +ve even before it crosses 2k and it has >5 psi by the time it hits 90 km/h. That's still <<2.5k rpm, so I think it's actually doing really well. Because of all the not-quite-ideal things that have been in place since the turbo first went on, it felt laggy. It's actually not. The response appears to be as good as you could hope for with a highflow.
    • Or just put in a 1JZ, and sell me the NEO head 😎
    • Oh, it's been done. You just run a wire out there and back. But they have been known to do coolant temp sensors, MAP sensors, etc. They're not silly (at Regency Park) and know what's what with all the different cars.
    • Please ignore I found the right way of installing it thanks
    • There are advantages, and disadvantages to remapping the factory.   The factory runs billions of different maps, to account for sooooo many variables, especially when you bring in things like constantly variable cams etc. By remapping all those maps appropriately, you can get the car to drive so damn nicely, and very much so like it does from the factory. This means it can utilise a LOT of weird things in the maps, to alter how it drives in situations like cruise on a freeway, and how that will get your fuel economy right down.   I haven't seen an aftermarket ECU that truly has THAT MANY adjustable parameters. EG, the VAG ECUs are somewhere around 2,000 different tables for it to work out what to do at any one point in time. So for a vehicle being daily driven etc, I see this as a great advantage, but it does mean spending a bit more time, and with a tuner who really knows that ECU.   On the flip side, an aftermarket ECU, in something like a weekender, or a proper race car, torque based tuning IMO doesn't make that much sense. In those scenarios you're not out there hunting down stuff like "the best way to minimise fuel usage at minor power so that we can go from 8L/100km to 7.3L/100km. You're more worried about it being ready to make as much freaking power as possible when you step back on the loud pedal as you come out of turn 2, not waiting the extra 100ms for all the cams to adjust etc. So in this scenario, realistically you tune the motor to make power, based on the load. People will then play with things like throttle response, and drive by wire mapping to get it more "driveable".   Funnily enough, I was watching something Finnegans Garage, and he has a huge blown Hemi in a 9 second 1955 Chev that is road registered. To make it more driveable on the road recently, they started testing blocking up the intake with kids footballs, to effectively reduce air flow when they're on the road, and make the throttle less touchy and more driveable. Plus some other weird shit the yankee aftermarket ECUs do. Made me think of Kinks R34...
