R33 2 door boot seal $15 pic
RB25 timing belt (brand new no packaging , was put on the motor and cranked 5 times but never ran) $40 pic
R33 2 door interior handles $15 pic
R33 2 door ecu kick panel $20 pic
R33 2 door rear view mirror $20 pic
R33 2 door map lights $20 pic
R33 2 door interior light $20 pic
R33 2 door series 2 console $50 pic pic
pick up from 5066 or postage at your expense
https://www.sau.com.au/forums/topic/330518-r33-parts/
do ya have a series 1 steering wheel or clock spring.
I need either one of the two to fix my friggen annoying horn problem because apparently my clock spring is stuffed.
I need either a.s.a.p to get my defect off
Cheers.
https://www.sau.com.au/forums/topic/330518-r33-parts/#findComment-5368714
Cheers.
nope only a series 2 .
https://www.sau.com.au/forums/topic/330518-r33-parts/#findComment-5369069
  • 3 weeks later...
  • 1 year later...
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
