advertising for a mate,
1998 GT-t manual, white, stock as a rock apart from 20" AU racing rims and an HKS ssqv bov.
factory sunroof, factory nismo body kit and nismo rear muffler with sports/normal switch in cabin
all the usual R34 options, 107xxxkm, had new standard coil packs fitted a year or so ago.
can come with the standard 17" wheels with near new tyres if you want them
more details and pics: http://www.carsales.com.au/all-cars/privat...3&silo=1011
make an offer, he really needs it gone ASAP! call andy on: 0416 605 500
D.
https://www.sau.com.au/forums/topic/331358-fs-r34-gt-t/
