Item: 16x7 Hinodex wheels, 5x114 stud pattern, + 30 offset
Website: Here and elsewhere
Item Condition: Gutter rash on one of the wheels, 2nd hand tyres fitted recently with average tread (previously had bald tyres)
Reason for Selling: Not needed
Price and Payment Conditions: $250 ono pickup only
Pictures:
  • 1 month later...
