Hey. Just wondering if my clutch might be going shortly or not? It squeaks most times and the release point in the pedal is very high.
Anything to worry about?
Also can someone post a link to the thread about the air con control lights and how to change them please? I cant seem to find it (even through search bar).
https://www.sau.com.au/forums/topic/331946-squeaking-clutch/
if it squeaks when you push the pedal in then it could be 1 of 2 issues. 1 is the bracket where the pedal mounts under they dash. the other is the pivot bolt inside the gearbox. the first issue is the easiest to check and fix. the second is relatively easy to check, but much harder to fix as the gearbox has to come out
if the pivot bolt is damaged in anyway then the next time you press the clutch pedal may be the last before it gives out and you lose all use of the clutch. when mine broke i pushed the clutch in and it felt funny, so i let it up and did it again. it still felt funny. i let my foot up and the pedal got nearly all the way back out before it shot to the floor. i could pull it back up by hand but the clutch didn't work.
I had the same issue on my old R33. It was the clutch fork which needed to be lubricated.
Squeaky when pressing and releasing, very annoying. Grabbed a can of motorbike chain grease and sprayed in the plastic flap where the fork is located. Annoying problem solved and cost me $6 to fix =)
  • 1 month later...
Mine has a squeaking sound audible from outside the car, which isn't all to audible for me but I don't like it being there :P
I'm assuming it's the pivot bolt. Where abouts should I look for that and do I need to take the gearbox out to greese it up?
you can fix the squeaking pivot bolt without removing the gearbox. you simply spray something like a spray grease in through the opening around where the clutch fork goes into the gearbox.
WD40 sounds like it'll do the trick :P
I had a mechanic do that on my Excel once but the squeaking soon redeveloped.
Is a lack of lubricant the only thing causing the squeak?
yeah it is. also wd40 is too thin, so the noise will come back after a few weeks/months. something thicker like a spray grease, motorbike chain lube, or even just a blob of grease on the end of a long screw driver (and then a small piece of wire to work it into the right area) will be better than wd40. wd40 isn't really a very good lubricant.
Any specific type of lube you recommend? I'll pop into supercheap or something on the way home.
  • 1 month later...
if you go to advanced search and search for posts about the pivot bolt and my name you'll find a pic i posted about it
Thanks Hugh. I haven't had a chance to do it recently, and I went to do it the other night and it wouldn't make the sound (it's a bit hard to work out where the sounds coming from when the sound isn't being made :whistling: )
If I get home by a reasonable hour tonight, I'll have a look...
For future Googlers
here is the picture. the pivot bolt is about 2 inches in behind that soft bit.
the picture is taken from the drivers side. if you stick your head under the car just behind the front wheel that is what you'll see.
Edited by SKITTLES
Thanks Hugh. I haven't had a chance to do it recently, and I went to do it the other night and it wouldn't make the sound (it's a bit hard to work out where the sounds coming from when the sound isn't being made :blink: )
For future Googlers
Further noting, it's on the drivers side of the gearbox, there's a medium, square rubber grommet... just pull it out on one side and move it out of the way.
I sprayed some WD40 in and it fixed it.. but give it a week and it'll come back..
What part in particular am I supposed to lube??
What should I be straining to look for? I can only really see a black single bolt.
you should see the clutch fork sitting on that bolt. that bolt has a mushroom shaped head on it and the clutch fork pivots on that. you need to lube up the top of the pivot bolt. you just have to spray a heap of lube onto the area and then continuously push on the clutch to work it into where it needs to be
  • 3 weeks later...
  • 4 months later...
sorry to dig up and old thread but im a little confused.
My clutch squeaks when i press and release it and im trying to diagnose why.
I'm looking under the dash to find the bracket that may] need greasing up but im not sure where exactly i should be greasing.
where should i be lubricating??
any help would be greatly appreciated!
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
