Ok... Sorry not at all good with cars, only new to the skyline side of things
I recently bought a 1998 GT-T R34 skyline. The engine light came on last weekend but there was no problem whatsoever with the way the car drove. My stepdad (previous mechanic) said not to worry about it so I didn't.
It has now started making a funny noise from the exhaust, which I believe is stock, and makes a funny movement which I can best describe as what a car does when your running out of petrol. It only does this when I am stopped or when I am taking off, after about two three minutes it's fine. I have been told it could be cold, spark plugs, or a crack in the exhaust. Sorry it's vague, I'm not good at describing problems...
Anyone have ideas?
https://www.sau.com.au/forums/topic/332002-help/
Engine check light comes on generally when there's a faulty reading from a sensor (of which there are far too many to list.) And no, you shouldn't ignore an engine check light. Take it to an actual mechanic, they'll hook a diagnostic tool up to the car and it'll list any recent errors the car has logged.
What you're describing sounds like misfiring possibly? Coilpacks die on cars of this age, that's something you should get the mechanic to check at the same time.
https://www.sau.com.au/forums/topic/332002-help/#findComment-5386671
Anyone have ideas?
my old r34 had the same issue and it was coilpacks so get them checked. im not saying that im 100% sure its happening with yours so id get them checked before paying a few hundred dollars.
https://www.sau.com.au/forums/topic/332002-help/#findComment-5386672
Thanks :) It's booked in for a service and they think its spark plugs and if it's not that than coils...
and should I take a male that nows about cars? because I quite clearly know nothing and it's my first car and first service...
https://www.sau.com.au/forums/topic/332002-help/#findComment-5386891
i think you should be ok, where are you taking it to?
https://www.sau.com.au/forums/topic/332002-help/#findComment-5386934
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW )
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
