guaranteed to make people think youre cooler than you actually are!*
Make/Model: Nissan S14A
Year: 1996
Kilometers: 165,xxx
Transmission type: 5spd manual
Engine: SR20DET
Colour: Red
Modifications: See below
Roadworthy Certificate: N/A
Accident History: None.
Asking Price: $15k... open to sensible offers though.
Contact Details: PM or call me on 0408961657 (after 5 pm).
Other Comments:
Regretful sale, but its time to move on.
Bought it dead standard in late '08 with 151,000ish kms on it.
Since then, I've done all this;
Interior & Electronics;
Clarion DB286USB HeadUnit
Clarion SRG1620R 2 ways (parcel shelf)
Clarion SRQ1620S Components (doors)
Unknown boss kit
D1 Spec quick release
Sparco R323 Suede steering wheel
NISMO Gearknob (+ dildo shifter for shits and giggles)
JDM S2 stereo, climate, and gear surrounds.
VELO GP90 Drivers Seat on modified Bride rail
STRI White Face Gauges for; Boost.
Shadow White Face Gauges for; oil temp, oil pressure.
PIVOT Water temp gauge
Bosch 6000K HID kit and arctic white parkers
Extended + battery cables
SuperCharge Slim battery
35% Tint
Alarm
Engine/Intake/Exhaust/Cooling;
Standard turbo rebuilt and highflowed to 2860 specs
Genuine Nissan coolant
K&N Oil Filter
HKS Alloy suction kit
Elf Excellium 5w/40 fully synthetic
NGK BCPR6ES plugs (.8mm gap)
Modified Airbox w/ cold air duct + K&N element
M/Steel 3" Apex'i Catback exhaust
AM Performance S/Steel Dump & Front (with seperated wastegate flow)
X-Force Catalytic Converter
Brand new Genuine Nissan Gaskets for; Mani -> Turbo, Turbo -> Dump, Cat
Brand new Genuine Nissan turbo studs
Brand new Genuine Nissan Water lines
Braided Steel oil line
Deleted BOV
Cooling Pro FMIC w/ custom brackets
Custom S/Steel 2.5" intercooler piping
Turbotech MBC (hybrid ebc wired in, needs tune)
Earls oil cooler and relo kit with speedflow fittings
R33 GTR fuel pump
Nismo Mounts
KTS Engine Torque Damper
Driveline;
Standard 5 spd Box
Xtreme Heavy Duty Organic Clutch
Nismo Mount
Standard Nissan "LSD"
Wheels & Tyres;
Front;
Work Equip, 17 x 9 +17
225/45 Kumho KU36 (brand new)
Rear;
225/45 Kumho KU36 (down to about 30%)
Brakes;
Front;
RDA Slotted Rotors w/ ACRE Street pads
HEL Braided lines
Rear;
RDA Slotted Rotors w/ Bendix SRT pads (less than 200k's on them, worth over $300)
HEL Braided lines
Fluid;
Penrite syn 600
Suspension & Steering;
Cusco Zero 2 R Coilovers
Cusco Front strut brace
Cusco Camber Arms
KTS Tie rod ends
Kazama castor rods
Body;
JDM Kouki wing
JDM front bumper w/ foglights
Navan Zenki side skirts
Navan Zenki rear pods
Rolled guards
Domokun chilling the rear quarter glass.
Performance;
136rwkw @ Graham West Workshop (Catback exhaust, exhaust leak at turbo, missfire, 11psi, 14/3/09)
171rwkw @ Morpowa (dirty and untuned, 2860, full exhaust, cooler, standard pump, 14psi, somewhat naffed pump)
170rwkw @ Morpowa, same as above, but with gtr pump and mega rich mixtures.
PB of 1:27:00 @ Mallala.
On top of all that, it has a brand new pair of kumho KU36's on the front.
And I'll throw in a set of blitz 550cc injectors, QFM A1RM rear pads (new), an ATS carbon single plate clutch (that needs a rebuild), and if wanted, i may be able to arrange a Z32 afm with plug for an additional $200.
I'll also be including, 4 stockies, 2 with legal tread, 2 without, standard dump and front pipe + cat, standard drivers seat, standard struts/arms/rod ends, standard front bar, standard intecooler/pipe work/bov, standard boost solenoid, spare rear garnish, spare bootlid w/out spoiler (does have holes).
I'm happy to remove parts to make it more affordable.
Its been religiously maintained, I don't stick to a service schedule so much as service it whenever I believe it's appropriate... or have nothing better to do. As such, it's been serviced with quality oils (at first, motul, more recently; elf excellium) and filters (nissan, and more recently k&n) every couple thousand kays (9+ times since purchase). It's most recent service was 2 weeks ago, changed oil, filter, plugs, fuel filter, and fitted a brand new k&n air filter. I'll be servicing it again in the coming days.
A compression test was performed mid last year for peace of mind, came back with 141-145 across the board, a leak down test was performed at the same time and returned results within factory tolerances.
A suspension safety checked was performed recently, with everything showing up apples.
And its passed regency with minimal work, standard wheels, borrowed standard exhaust (or baffle plate), standard boost controller, removed gauges, standard seat, and it's through without incident.
Also, unless you make me a sweet deal, it will be sold with the standard steering wheel, not the sparco.
Now for the bad. there are a couple small chips in the paint, and some poorly repaired parking lot damage to the rear drivers side guard. I'll get pics of all this up later... and that's about it.
Basically, as it is, it's an lsd and a remap away from being whatever you want, drift car, grip car, hills car, or just leave it as is and have a bullshit tough streeter, it's up to you.
*guarantee may not be valid in Australia.
Edited by scandyflick
https://www.sau.com.au/forums/topic/332285-96-s14a-pretty-sweet/
i started selling it for 18, and i was pretty firm on that. im now taking offers at 15 and the only thing im keeping is the steering wheel.
Yes do recall it being up for 18, only problem atm is people only looking to pay stock prices you remember the blue one owned by the chick, thought she had dropped a cylinder turned out to be oxy sensor, sold for under 12, it's hard finding buyers for more because of the price drop in 34 gtt's take some gear off it take the price down and I promise a buyer will come along the last 3 that sold on NS sold for between 11 and 12 and from memory the series ones are goin for about 9, I know it has more value to you and I know the feeling I'm trying to sell a car myself 2000 under value 6000 less than what dealers are selling em for and still no calls and the only offer I've had was 5000 less than it's advertied for
yeah, its a shit market.
meh. if someone came along and offered me $12k for it sans wheels, suspension, seat, injectors, and gauges, id happily take it.
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
