Hi everyone apologies if this has been asked but ive searched and had a bit of conflicting info!!
Ive got a 2005 Manual Coupe and im wondering how i find out if its a rev up or not.
Some infomation ive found is you can tell by the redline. 6500 - Non Rev Up 7000 - Rev Up. Well my redline is 6800 :P
Also on my dash ive got Rev illuminated,which some sites have said this is only on rev up motors,but some say its just for a shift change light.
Im looking at buying a supercharger from the states and would appreciate someone with a bit more knowledge than me to confirm and if ill have any problems with the kit.
Thanks in advance
Spenny
https://www.sau.com.au/forums/topic/332350-rev-up-or-not-rev-up/
Thanks guys!!
Just one last question then. The guy selling the supercharger says his is for a non revup. Is there any difference in ours to the states in terms of fitting a supercharger???
Thanks again
I believe that the answer you are looking for is in the engine designation prefix, i.e. VQ35DE - non rev-up and VQ35HR being the rev-up version, HR standing for high rev.
p.s. This is only a theory of mine, so if I'm wrong can someone please correct me. :woot:
Hi Thanks for the quick replies.
Im looking at a procharger kit!! Any feedback is appreciated as im still unsure what way to go.
Thanks
Spenny
It should fit, but with Procharger just be aware that it's going to be really loud and whiney. If you're OK with that then it's also reputed to have very good power potential. The other thing to make sure of is that you have proper control of timing and fuel. In order to get a safe and reliable set-up you will also need injectors (480cc minimum) and a fuel pump.
Some kits come with split-timing boxes and do the extra fuelling with an extra injector in the intake tract. Not ideal but it can work...sometimes. Anyway good luck with your install, supercharged VQs are heaps of fun...
It has taken me a year and a half and I only just discovered the shift light on the weekend. It has always been set at 8000 and therefore has never lit up, so after filling with fuel and resetting my trip, I tried to work out what the 8,000 things was. Messed around and managed to change it to 2000 thinking it was some sort of service interval setting and drove off only to find the light start flashing at 1500 and solid at 2000.
It was pretty exciting there for a few minutes, now I've set it back to 6000 and probably wont see it again for 6 months :blink:
Yeah i found it too,i think i lasted 5 gear changes and i was changing it back to 6000 also. Wish i could get rid of the rev illuminated.
It was pretty exciting there for a few minutes, now I've set it back to 6000 and probably wont see it again for 6 months :action-smiley-069:
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
