Hey guys,
i have for sale a stainless steel top mount turbo manifold to suit RB20DET or RB25DET, held 17psi easily and made around 220kw at the wheels,slightly used but still in good nick, selling due to defect.
It still has the turbo (T3/04E) attached which is a jjr ceramic turbo, re-built with all Garrett internals, rated to about 400-500hp, also has 3.5 inch dump pipe.
Also still attached is a MonstA 38mm with plumbed back screamer pipe, but the plumbed back pipe would be easy to remove.
Can separate parts if you want them individually.
Turbo and dump pipe- $400
Manifold with screamer- $120
Waste gate- $90
The lot- $600
Check my gallery for some pics when they were in my car still, i can take more now they are out if anyone wants them.
Any questions please feel free to ask?
ive uploaded the pics as a separate gallery on my profile....
http://www.skylinesaustralia.com/forums/To...-album3901.html
Edited by Camo87
for those that are too lazy to view the gallery i put up, here are the pics of the manifold etc.
make me a reasonable offer guys, it needs to go....
  • 2 months later...
HEY MATE WOULD YOU TAKE 300 FOR IT??? HOW HIGH DOES IT SIT IN THE engine BAY approx??? like above the top of the motor or below??? I CANT SEE YOUR PICS STILL NOOBING IT WITH THIS SHITE LOL.. Cheers Angus
  • 11 months later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
