hey skyline lovers,
purchased a drift electronic rpm gauge just trying to find my tach signal i have flush mounted my gauge and now trying to find the tach signal from my coil ive unscrewed the allen key bolts on top of the head and am now stuck with the signal wire and finding my leading coil
can anyone please shed some light on this or will i have to wire it up to my ecu somehow
this is a head case and a half i really am starting to get pissed off haha,
tryed attaching my tach signal on my digital rpm gauge to the yellow wire with the blue stripe after i stripped it behind the dials, also tryed the yellow and the green striped wire and just connected the + and the - to a battery that i got lying around, started the car and no luck...
the guy at autobahn said i have to connect it to my leading coil im in a real pickle at the moment my whole dash is apart and from 7p.m-2a.m ive been trying to sort this motherf*%$#r out and it wont work... will i need to connect it closer to my ecu or have i got the wrong wires completely? :):)
Whats wrong with the awesome tacho next to the speedo that came form factory??? Get a shift light, preferrably one of the pencil types that don't stick out like dogs balls and then you'll be set...
hey,
the rpm gauge that i currently have is flush mounted in my old cluster it has a inbuilt shift light about the diameter of a pencil if not smaller i believe this one looks 10x better i was just wondering if anyone could help with the wiring and how to connect this electronic rpm gauge to which signal wire if not wires
cheers chris
had it connected to pin 7 (yellow with blue stripe wire) behind the cluster and temp to a + and - on a battery i got lying around and no rpm reading
will it have to be conencted closer to my ecu for a rpm reading?
thankyou for everyones time chris
found a interesting thread that makes me think i have the wrong signal wire could it be pin 7? which i allready have tryed behind the dash cluster or could it be pin 53 "which is the Vehicle Speed Sensor signal is basically engine rpm's"i have read to connect it closer to my ecu for a reading but i would have thought if i have the yellow and blue striped wire (pin 7) behind my cluster i should get a reading the gauge is electronic/digital if that makes a difference?
here is the thread anyways http://www.skylinesaustralia.com/forums/Rp...ed#entry4042455
was reading over a thread a while ago and im not sure but dose anybody think i might have to attach a resistor and a tacho booster i have no signal from pin 7 which i connected behind the dash cluster which is the yellow with blue striped wire i will re-connect it tomorrow to pin 7 from my ecu
any ideas/thoughts much appreciated chris
its a multi cylinder gauge can be switched once the power is fed to it with a click of a button...
went out today and purchased a signal booster for my ecu for $160 as i was told that is my problem as the current coming from the ecu is only 5-7v and the tacho is 12v when i power it to a battery it lights up/illuminates but when the signal wire is connected to pin 7 no rpm reading once the car is running and the gauge is set for 6cl mode
    • What's on the front of their building?
    • Jax Tyres Smithfeild Ive gone there a few time, well for tyres. on my 3rd visit I spoke to the dude and told how i just got slugged for rotors, brakes ect. His reply was golden; have you read whats on the front of the building. Never forgot it.       before picture, good friend got all these goodies installed.  Well time to study, servicing, maintenance all before this weekend driving lesson.
    • Hello, first of, I’ve looked at many threads on this code but none have helped me, if you know one that will help me feel free to post a link.   Now to my problem. Recently I was driving and noticed the check engine light came on. I went home and did the test to see what code it gave. I got the 21 code but everything seems fine with the car, no misfire, idle is good, acceleration is the same as when I bought it. I mean no signs of obvious failure. If no misfire is happening I can rule out the coil packs right? Which is about 98% of posts saying it is. If anyone has had this happen and found the issues let me know please. No other lights are on.   The car WAS due for an oil change. I since then changed it so idk if that triggers code 21. Either way it hasn’t turned off.
    • Your both right, it may hold a bit longer then.  Soon I need to change the synchros, should I fit the billet plate while I'm at it? Or just a waste of money?
    • Some of the east coast US Stagea got together this past weekend at Lime Rock Park in CT for Grid Life Circuit Legends. This is probably my favorite pic of the shoot with @Morgan.Mundahl on IG. Hope we get more stags out next year! i think I spotted 5 other than my own at the event.
