  • Replies 225
Posted Images
erm, okay im confused, this = second hand kit???
from what i can see... you have a wonder type 1 front bar - not type 2 as shown in haruyama's old project car...
and URAS sideskit..
i can not quite see the rear bar so unsure of what that is :)
but the orange cefiro has wonder Type 2...
you have something else...
hey everyone. remember that guy who stiffed me on the price of those weathershields and never sent them then you guys told me track his number and text him?
well - i tracked his number and texted him. twice. still no reply.
what you guys reckon i should do?? this was like $150 odd on somethig that should've been half that price. i'm - actually starting to feel a little bit pissed..
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
