  • Replies 225
Posted Images
  • 4 months later...
Maybe.
Wanted to ask the guy at the red light but just couldn't quiet get along side him :\
So, in other news:
I got my gearbox out tonight.
! hour 20 mins, including jacking car up, driveshaft, diff, and getting the box on the ground and out from under the car.
As it turns out....there might be nothing wrong at all with the box, the clutch on the other hand, farken LOL.
Heavy wear on the inside of the compound (10mm section on the inside has about 1.0-1.5mm more wear), the compound itself was shithouse...half the clutch just crumbled as soon as I pulled it off, and the flywheel has scorch marks all round.
So....maybe the crunchies was clutch engagement...since the box hasn't even been leaking oil.
Hahahah...ah....ha....eh.....gayest story of my life :(
Just wait for the next HSV they will try and squeze that motor in to keep up with everyone else.
I had something similar with my 1st 180, car wouldnt go into gear one minute, then fine the next, crunch gears etc, thinking its farked. Pulled the box out and all the clutch plate springs fell out.
I didnt install the clutch...I pulled it out of the halfcut, looked at it, still heaps of meat left on it so I just chucked the good gearbox on it and threw it into the Ceffy...Stock clutch, 126xxx kms...dare say it was the factory clutch ?
Doesnt matter, new flywheel and GTR clutch on now....
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
