1995 WHITE R33 GTS-T M-SPEC
This car is in very good condition, I've serviced the car every 5000kms and usually only take it out on weekends. I've never actually had a chance to dyno or run it on the track yet. The reason I am selling is because I know have a family and need something more suitable for my needs. It's a regretful sale but I have to do it.
- 5 Speed Manaul
- 78,000 Original Kms (Log book from Japan to prove)
- Immaculate Condition inside/out
- Works 17" Gold Deep dish rims
- Nismo 400R front bar
- Nismo Eyelids
- Nismo Grille
- Auto metre Boost Gaugue
- Razo Gearknob
- Sony Headdeck
- Full Mongoose alarm and immobiliser
- All standards still included i.e. Airbags, Climate Control etc.
- UH OHH number plates might be included
Mods:
- T3/T4 Hi-flow Turbo
- Full exhaust from the dump pipe with Hi-flow Cat
- GTR Intercooler with full custom piping
- GTR Fuel Pump
- Blitz Super Sound Blow off Valve
- K&N M's Pod Filter
- GReddy ProfecB Boost Controller
- Front Tunabi Shocks and Springs
- Strut bar
- Aftermarket 1by1 lock diff (Both wheels spin)
- Apexi SAFCII
- Blitz Turbo Timer
- Irodium Spark Plugs
- Heavy Duty Brass Button Clutch. (only 2 weeks old)
- Heavy Duty Pressure plate (only 2 weeks old)
I'm looking for $20500. Any queries or such please contact me on 0414884432 and ask for Richard. PM's and emails to [email protected] are more than welcome.
Pics are available at:
http://www.gourou.tk/seti/front.jpg
http://www.gourou.tk/seti/angle.jpg
Yeah I reckon the car is definately underpriced too. But I wants a quick sale because as i said my stated family requires a different alternative. Im looking to get a WRX 4door if anyone is willing to make a swap.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
