Just installed an amp and I'm having amplifier engine noise problems. I've done searches and will try and figure it out but I was just wanting to confirm which side of the vehicle is best for running the RCAs?
I've got them down the passenger side at the moment (cleverly running right past the ECU!), is this the best way?
Also, I've got nice heavy 4GA power/ground lines on the amp, do I need to mess with the wiring on the pioneer head unit? (I'm thinking not?)
Car is a 33 gtst.
Cheers,
John
https://www.sau.com.au/forums/topic/33358-quick-amp-question/
G'day John,
Damn these R33 GTS't are so bad for engine whine :) I've got the same problem....
I reduced mine by running the RCA's as far away from any power source as I could. For me that meant running the RCA's up the middle of the car. Not sure if this is the best but......
I also put a power filter on the head uint which didn't do much, so it must be getting into the low level stuff feeding the amp.
I also found that if you earth everthing really well it seems to help reduce the whine.
Anyone else had much luck ??
J
I ran mine down the passenger side, have had no problems. Where did you mount the amp and where did you ground it to ?
At the moment the amp is just screwed into the base shelf of the boot (carpeted MDF). It's grounded (4GA) at the same point the battery is grounded, and the power (4GA) comes straight from the battery terminal via a fuse.
Don't ground it to the same one as the battery. This can cause problems, also what brand amp are you using? some of the cheaper kind and really bad for nosie. A friend of mine had a cheap amp with a really bad whine through it, then he upgraded to a decent amp, noise gone, and we didn't change the wiring at all.
I'll try moving the ground and see what happens.
The amp is one of those Jaycar AA-4035 4x100W rms amps (being discontinued and on sale at the moment for anyone who's interested). A cheap amp compared to some brands but they're supposed to be ok as far as I know...
Anyone else out there with one of these amps who's not having problems and can let me know how they've wired it up?
i just recently did an instal (which amp for my 2x 12"subs post). Mine sounds awsome, no whining noise what so ever,and HUGE bass & clarity, I'm running Rockford Fosgate head unit, earthquake 6" splits front Via old Sony EMX700 2 channel amp(soon to be upgraded to Soundstream RUB 300-2), rear stockie clarion paper cones running off head unit, and 2 x 12" orion subs off a Soundstream RUB500-2 2 channel amp. Both amps are in the boot right next to the battery, RCA leads I ran down both sides of the car, passenger side for front splits amp and drivers side for sub amp. remote wire for both amps down passager side, LH split speaker wire down passanger side to amp, RH split speaker wire down drivers side to amp. Earth to car body, power through fuse then to a slit block to provide power to both amps.
May or maynot be worth mentioning that my R33 came with a top quality earthing kit throughout the car, wheather or not this makes a diference or not im not sure?
Seems to have sorted itself out, I just cable tied the rcas and moved things around a bit and I can't hear it anymore.
I've not had car sound running off a seperate amp before, speakers sound amazing. The amp in the Pioneer 6450 headunit was apparently really really bad at any kind of volume, and had me wondering about my shiny new JL audio 6x9s. (The inbuilt amp in my old bottom of the line sony head unit seemed to pump out much cleaner power than the pioneer)
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
