hi peps...
my left sideskirt at the moment is loss..the sealant that holds the entire skirts is not working anymore (still got the screw both ends to hold the skirt)..anyone can suggest me what to do>?? should i get somesort of a sealant/glue thingy to glue it back up?? if so, what product do u guys recommend?? or should i take it to the workshops and spend $$$ on it??im thinking of doing it myself...its only one side anyway, the other side is perfectly fine...
cheers pepzzzz
https://www.sau.com.au/forums/topic/333946-sideskirts-flopping/
def sikaflex
-you ever tried getting out the tail-lights on an R33? feels like they are held in by about 4 massive bolts when u know there are no bolts left holding it in- thats sikaflex :blush:
take the skirt off first and clean as much of the old shit off as possible for the best stick and look of the job.
def sikaflex
-you ever tried getting out the tail-lights on an R33? feels like they are held in by about 4 massive bolts when u know there are no bolts left holding it in- thats sikaflex :)
^+1
They also use it to stick the hair to your head. Ever tried pulling it off? It's painful, frustrating and if you do want to remove it you end up cutting it off.... :(
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
    • Nice, that's not laggy swtching between functions at all. Could it be less laggy than the factory one below? 😋
