hi guys, i have been looking around for a while for a 32 gtr but having lots of problems with dodgey buggers. i found a gtr in vic and done a vehicle search on it. it all came up fine but it says the car is an auto. has anyone had this problem ?? the only thing i can think of if its not a mistake by vic roads is its had a gts4 drivetrain put in or somethin dodgey. do u think this is possible or am i bein paranoid ? what looks different between the 2 drivetrains ? what should i look 4 ? i done a search of a few different number plates belonging to victorian gtrs and some of them come up auto aswell. i just dont want to travel from my home in qld to vic to get this car if its dodgey. any help would be greatly appreciated.
https://www.sau.com.au/forums/topic/334269-gtr-drivetrain-identification/
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
