$1,000.00 dollars cash has been put up by Powercruise for the fastest lap at the Jap Nats 26th Sept.
Competition is limited to 100 cars with the fastest 20 sprinters from the morning being invitied to take part in a 1 Lap Dash to win $1,000 in cash.
Entry forms are available from: http://www.queenslandraceway.com.au/pdf/e_...atEntryForm.pdf
Get your entry in now as only 100 entries will be taken
https://www.sau.com.au/forums/topic/334444-jap-nats-at-lakeside-26th-sept/
Oh don't worry! I'm hatching a plan!
What, are you going to borrow the Option 1 S14 :starwars:
If a certain person was not involved in this event I would have entered but a 60 will not be good enough to win so meh.........
Edited by 260DET
Exactly, should be a great day! I haven't seen an entry list.
Berry's gonna bring the 32 so that'll be fantastic.
No doubt there'll be plenty of stuff to ogle at in the car show too.
I gotta get someone to drive to 34 out to display.
Get on board Ben.
http://www.sauqld.com/ipb/index.php?showtopic=2866
I'm out.
There was 1 thing that I was not happy with when i was building the enigine, the rings just didn't quite sit right. They were a set by JE as ACL couldn't supply any rings for them. I have done 10,000 km on the new motor running 12-14 psi and have pulled it down as part of a diagnostic process. I wanted to see how the rings were doing in particular.
The bearings, bore, buckets, cams etc are perfect, the rings though, "Not, Happy, Jan! uneven ware.
I have done some homework over the last month, ACL changed the ring specs part way through the production run. So, there are 2 different ring sets for 1 pistion part number. You can't buy a ring set for the earlier spec pistions, I have the early spec pistions. I'm pretty sure they were made by ROSS in the US for ACL. Ross can supply a set of rings for us, will just take a while.
Unfortunately I won't be compeeting, but I will be watching and snapping shots.
bugger :) will you have it together for the QLD Champs at Morgan Park?
I'm looking forward to both these events. Diff's coming out tomorrow - tired of the open wheeling viscous diff so I'm planning to weld it up. Would love to get hold of a wing too, but I think I've left it a bit late.
ended up shimming the V-LSD instead. Mainly so that its still nice to drive on the road. Hopefully it works OK on the track for a while too. Should be a few tenths in that if it eliminates some wheelspin. Cost next to nothing thanks to Paul at Option 1 Garage, so I figured its worth a try. Plus it maintains my 'full street trim' excuse >_<
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
