hey guys i got my r33 gtst mspec with all series 2 parts on it that im thinking bout wrecking, just wondering if any1 is interested in any parts so i can make a decision whether its worth stripping or not???? Everything is in perfect condition and colour of the car is yellow
need driver side window switch
front left and right guard inserts
all the stuff from the boot
dash den
front bumper
any after market parts in good condition ( intercoolers, BOV, wheels, tyres, suspension , etc)
whats the windsreen like ( hard to get out without breaking the thing though)
thanks in Melbourne call 0404099310
thanks for the reply guys much appreciated!! i will be making my decision by end of next week, it just hurts to strip this thing coz its so god damn clean and can be put back on the road so easy! :(
