The following items are now for sale:
1994 SR20DET blacktop engine with 5 spd. (57,000kms) $2900
Toyota AE86 LSD with calipers and rotors attached. $800
Toyota AE86 EFI Fuel tank. $300
1 Litre of custom pearl black paint (makes 4 litres once mixed up with clear coat). $300
Autometer phantom 30psi boost gauge, Autometer phantom Air/Fuel ratio gauge, Dual gauge Pillar pod (the pillar pod suits nissan 200sx S14 - though it seems to fit well in a few other cars). $200 for gauges, $80 for pod.
Alpine CDA7876RB Electronic flip face CD head unit. Excellent condition. $450.
I am also selling the number plates D1 SPEC which have never been used on a vehicle. Make an offer.
I've no idea how much it would cost to send to sydney, but i suspect the price would be high due to the weight of the diff (very heavy).
I will not seperate the SR gearbox from the engine. It is to be sold as a complete unit.
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
