hi guys i get coolent leak inside the car/passenger seat ,is it a/c or some other fault? i dont use the ac anyways cause i have no a/c belt is but before the leak the a/c was turned on by mistake now some one said its the ac leak that you get after not using a/c for long periods which in my case is right but why do i get too much leakege ?
when you dont use the air con for a while the seals in the compressor can dry out and you lose gas. if the liquid is from the aircon it will only be water and would mean the drain is blocked. but if its still leaking and you dont have an air con belt then it must be coolant from a leaking heater core or one of the hoses from the firewall to the core. turn the heater off for a bit to see if it stops, wipe a white rag on wet spot to see if its green(coolant). prob more chance of a weeping hose than the actual core.
hi mate thanks for the reply heater is off but its still leaking green which is coolent and i dont know how to reach there to see which hose is that
the heater hose connections are located at the firewall,if it was leaking you would see it in your engine bay.i suspect its a leaking heater core.way to fix this problem is to take your heater box out and check out your heater core,very annoying job though
even if the heater is turned off it can still leak as only one hose has a tap on it. as Todd sys check the tutorial so you dont have to pull the dash out
  • 1 month later...
Where is this tap btw? It must be on the engine side of things, as the heater core doesn't have one, nor the plastic angled pipes that you connect to it. I don't see anything in the rubber heater hoses either.
    • Jax Tyres this Monday morning. Front lifted 15mm Back lifted 12mm Quote1, $175 per tyre + wheel alignment. Quote2, $660 inc wheel alignment. paid $298 for the lot.
    • Finally have an update on this  Rack came in this week so I did a test fit. You do need the S chassis bushings since the rack is 5mm thinner than the R33 rack. The main issue I foresaw and ran into was one of the hardlines not lining up properly with there it's meant to on the rack. After some gentle coercing and bending very slightly, I managed to get it to fit without any kinks and keeping the hardline pretty much in all of the factory mounting positions. I did have to unbolt all of the soft mounts to move the line around so I could snake it out and bend it safely but it looks good to me for now. I'll update when the rack is fully bolted in and functioning.
    • I hear this thread needs an update following its adventures last Wednesday!
    • What are you thinking makes a sequential shit to drive on the street? About the ONLY thing I can think of, is if you're wanting to be able to roll up to lights in third or second and pop it straight into neutral, or you want to come down two or three gears, say out of 5th and back to second, but they shift quick enough it doesn't really matter
    • I'm not a drag racing guy, but that was a good watch. Didn't Ibrahim's car have some cooch! But the big question is....WTF is with so many of them running without seatbelts!
