BNR34 NUR SPEC N1 TURBO'S comes with oil lines and NISMO stainless steel extensions. Price the Nismo extensions...they are over a Grand by themselves.
The turbos are basically new...the guy that owned the NUR SPEC upgraded them straight away.
You will not buy better....basically complete and new in everyway and they are perfect for the street (can hold 1.7 bar) better than buying real secondhand.
You can alway buy real secondhand 2530's and hope for the best and they won't come with the extensions, oil line or anything else.
enough said condition is everything when buying turbos and I known you will never get another set, of this Quality for this price.
$4000 or best offer....
Phillip
0409 573 124
[email protected]
[email protected]
https://www.sau.com.au/forums/topic/33505-bnr34-nur-spec-n1-turbos/
The different between NEW and BASICALLY NEW is price.
It's as the words imply.
New is delivery k's on the car.
Basically new is not long after that they were removed and upgraded.
Your in Perth....if you were serious....I would send you the turbo's to view and inspect.
But, it sounds like your not happy, with being asked you to increase your offer.
The offer is still there....if you are serious....increase your offer....and I will send the turbo's and extensions to view and inspect.
What more do you want....another 20,000k's on them to bring them down to your offer.
You have my number (0409 573 124)
regards Phillip
CONDITION IS EVERYTHING, when buying Turbo's
So is being polite to potential buyers.
Daniel Konig
If you are not interested in buying these turbo's then please keep your comments to yourself. I'm thinking you should have a read of our rules.
Thanks
Neil.
Yes....people should alway be polite!
But not for the sake of a sale.......and not forsaking honesty.
I've had a lot of inquires from people in PERTH....waiting for the serious buyer though.
Just for the fun of it....if the buyer is eventually from Perth...he or she can have them for $3500 with the extensions and I will through in a NISMO dump pipe to go with them for $250. However, the offer ends at the end of the week.
Phillip
0409 573 124
MESHMESH
Are you interested in buying the NISMO extensions (small pipes from the turbo's exhaust housing) or the dump pipe? (the longer 2 pipes into one)
"Have you got a pick of the dump pipe?" there is only one Nismo dump pipe. It's a long 'Y' piece pipe from the 2 turbo's extensions, to the cat.
"Would you sell this seperatly?" YES, if the offer is reasonable.
"Is it a split dump?" I assume you mean do the extensions have a separate wastegate outlet. YES, they do...the turbine exhaust housing, also has a divider between outlet and wastegate.
"Do you know whether this fits the stadard turb's on the gtr?" I assume they would.
I hope this answers all your Questions.
Thanks for the inquiry.
I just would like to clear up a confusion and be as polite as possible during the process.
That is the front pipes dude.
What you are referring to as extensions, are the dump pipes. These are, what meshmesh is interested in, i believe.
I apologise in advance for my interruption.
:D
I think you understood, the exhaust pieces I described.
Yes, they are front pipe and dumps in some circles and extensions and dump pipe in another.......the second makes more sense to me.
The same applies to the term SURGE Tank and Plenum. It all depends on which terms you are use too, in conversation and what makes more sense to you. Plenum for me in this case.
No need to appoligise for interuption.......all knowledge is good.
Phillip
  • 4 weeks later...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
