HEY GUYS,
I have a set of 6 Blitz 525cc Injectors for sale.
Injectors have only done 2,000kms and are in very good condition, pretty much brand new.
Also have a Z32 Air Flow Meter that i need gone as well. Also in very good condition
$750 - Blitz Injectors
$250 - Z32 Air Flow Meter
Can do $900 for both.
Shipping at buyers expense.
Im from Melbourne, Victoria..
Pick up is also available
PICTURES WILL BE UP SHORTLY GUYS,
Thanks =)
Edited by p.dellaglio
Any pictures of the injectors? Are they a direct fit? Would they require spacers for the fuel rail? Have they been checked?
Hey man,
They fit in perfectly although they are a bit long so the spacers come with them for under the fuel rain.
Ill put some picks up hopefully tmoz.
They work 100%
Ill get picks up tmoz.
cheers
Anyone want to make an offer?
Sorry i havent put piks up yet, been so busy with work etc.
Will try to by the end of this weekend.
How much rwkw's can these injectors handle?
Well even though the standard AFM in the 34's are solid, your better off bundling the Z32 with it as well. Both together will get you 300rwks SAFE.
cheers
Are the spacers the only modification required to fit, or do you need different plugs?
Hey mate,
Nope, no other mods needed... the spaces fit under the fuel rail and thats it!
Nothing else needed man :)
hey mate just confirming that these will fit the rb25det NEO motor? and what sort of power/boost would they max out with a gt3076? sorry pretty new to the scene. please pm me with the lowest you will take for injectors and afm. and a rough postage price for sydney. sorry post count too low to pm you. thanks
Hey man,
With both the afm and the injectors, and then if you get yourself a tune as well, you can EASILY push 300rwks safe.
The standard afm in the rb25's can take 200-210rwks. (im kinda new on the scene as well, thats what i was told by someone with a bit of experience)
Ill PM you a price, but its $20 for the postage to Sydney,
Cheers,
Patrick
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
