Hello All,
Due to an engine swap i have the following stuff for sale. All came out of my R34 with 76'ks on it. And all in excellent working order.
Im in Brisbane but am happy to arrange postage on the smaller stuff but you will need to arrange a courier if you want the bigger stuff.
Will sell as a package or separate.
RB25DET - 76000km's Complete minus loom inj/coil packs/turbo - oil change done 1000km's ago and always changed every 5tho. - $1500
Apexi Ax53B70 on a aftermarket low mount manifold - Inclds braided water / oil lines & dump pipe. - $1500
Nismo 600cc Inj - $550
Splitfire coil packs - $450
RB25DET Gearbox with Exedy Twin Plate Clutch - only ever run redline oil. $1500
This combo was making 240rwkw on 1 bar safe tune with awesome responce.
Looking for $4800 as a package. If bought as a package will throw in a HKS front mount with piping to suit.
Please PM for more details or can arrange photos if needed.
Edited by ls1ben
Few pics below. Turbo has zero shaft play/fins perfect and overall excellent condition.
Engine does come with a/c & p/s - only took it off for easier removal.
Yes i am. I have had a few pm's about it. once i remove the box ill get some pictures up and will be open to offers.
Also, coil packs are sold!
Is the injectors to suit rb25det NEO? I thought Nismo only made 480cc injectors for the NEO.
How much would you be looking for the HKS intercooler kit? And the exhaust manifold? Anymore info on manifold?
My apologies, Yes they are off a NEO so they must be 480's then as its still stock fuel rail. I wasn't sure and just saw that they were purple tops and googled it and found that 600cc are purple but now I see 480cc neo's are purple too! Thanks for pointing that out!!
So - 480cc Nismo NEO injectors - $550 make an offer!
I have a bit of interest in the kit so wont split the manifold and turbo at this stage. But ill let you know if I am willing too.
As for the cooler kit. Ill organise a photo and you can make an offer. Not sure what its worth.
Thanks Jin, Enjoy!
Sorry about the delay on intercooler pic. Here it is. make an offer?? There are a few more silicon joins with it as well.
Everything is sold except the turbo on the manifold with dump.
Thanks Jin, Enjoy!
pm me lowest price and dimensions mate very keen :P
p.s is it direct bolt on for r33 gts t rb25det..
cheers
  • 4 months later...
  • 2 years later...
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
