sorry for the topic
but
i have an application with dotars at the moment and the last contact i got from them was in the end of august and iv had nothing from them since.
is something going on there or are other people having the same problems??
i have emailed them this week but still no contact from them.
itll be a month since i got their last contact on monday.
im pretty over waiting at the moment :D
https://www.sau.com.au/forums/topic/338050-dotars/
sorry for the topic
but
im pretty over waiting at the moment :P
What is the application for, Personal Import or Race Rally.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5464661
personal import. the last they said was if you provide us xxx document we will issue it.
but still nothing from them yet
Personal Imports, Pre 1989 and Race Rally are lower priority and they are looked at a lot closer, when someone submits a statutory deceleration stating it is a steel bodied 1937 rod and when inspected on the docks they find out it is a fairly new fibre glass bodied rod well they are vetting everything a lot more.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5468067
obviously that happened recently?
personal import might be a lower priority but its been over a month since the last time they emailed me. its just a joke now.
surely theyd contact me to tell me whats going on????? i did everything they wanted me to do.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5468193
I was told about it earlier this month so I would think it happened last month, it shows how game some people are and how the minority stuff it up for the majority.
If you emailed them a week ago I would email them again and only then call if no reply, I have had issues lately with there email system and a call was required.
https://www.sau.com.au/forums/topic/338050-dotars/#findComment-5468712
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
