hey guys
my car wont start ;/
the starter motor was clicking and not doing anything so have replaced that and still nothing
the only way we got the car to start was by jump starting it and having a jump pack on the front while the other car was jump starting it , THEN it started
let it idle for 10 minutes , shut it off and nothing. wont start again just clicks...
the alternator was showing 11v on idle but went up to 13.5v when revved
could it be the alternator ?
i replaced it just over a month ago and put a new battery in so it would be weird for that to happen :P
https://www.sau.com.au/forums/topic/338332-r33-wont-start/
The output from the alternator should be regulated at approx 13.4 volts but even a faulty regulator shouldn't stop the car from starting, unless the battery is already flat How many volts is your battery reading with the car off?
Battery might have dropped a cell or there's a faulty + - connection somewhere
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5467863
battery is returning 12v when the car is off
have the battery on charge now to bump it up to 13v
just tested my mates battery on his r33 and it returned 12.7v when its off & 13.8v when its on idle
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5467919
voltage reading wont mean that the battery is fine. if youve shorted anyhting out with the water in footwell thing its quite likely that the battery has dropped a cell and gone. chuck another one in there that you know is fine and see what happens...
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5467988
have done that bro...
ive got had 3 different batteries in the car in the past 3 hours and same with every battery
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5467995
Letting it idle for 10 minutes aint enough to charge a battery...
Just disconnect the battery when your not driving it so nothing drains it.
and when i want to drive it , get someone to jump start me while i put a jump pack on it ?
right :P
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5468017
3 New batteries doesn't fix it (provided they're fully charges), not a battery problem, you've replaced the starter (with a new one?) , probally not a starter problem. I'd start chasing a connection issue.
1. Is the relay clicking or is it the starter/solenoid itself clicking?
2. If you connect your jump-pack/vehicle's earth to a point on the engine, and the + to your + jump point in the fuse box, does this allow it to start easier?
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5468039
So it wont start with just a jump pack, and it wont start with just jumper leads...
Jump packs on the front, so I assume the car is jumping from the boot?
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5468046
so confused right now o.O
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5468053
correct.
only time the car will start is if i have BOTH connected (battery on the back and jumper pack on the front)
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5468054
The starter motor is just clicking, sort of like when a battery goes flat?
A starter will draw well over 100a when cranking, if any of the cable runs are damaged (by water for instance) and are not capable of delivering 100+ amps (high resistance for example) then you will see similar behavior to that of a flat battery.
Check the condition of the cable run from the battery in the boot to the engine bay, see what resistance reading you get.
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5469212
where abouts does it run?
ive got no interior in the car so theoretically i should be able to see it easily? :laugh:
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5469488
Lol. I assumed you were trying to jump start it from the battery in the boot, not the factory jump points in the engine bay, this would bypass the wiring from the battery to the starter, and eliminate it as a problem, along with your earths (by hooking the earth directly to the engine rather than the negative terminal of the battery).
Since you have done this already, and jumping it directly to the factory jump points doesn't work, check the lead from the fuse box jump point to the starter is in good condition and that the connection on the starter is tight (disconnect the battery before you try this), if this is all OK and it still won't start, your remaining options are:
1. The jump/pack leads you are using aren't good enough
2. The starter motor is faulty
3. The starter solenoid/relay/circuit is faulty (which can be checked by bridging power directly from your leads or starter main wire, to the solenoid switching wire)
4. You're doing something wrong
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5470061
ive got no interior in the car so theoretically i should be able to see it easily? :happy:
It runs under the car, from the battery, through the floor, across to the drivers side "rail", along the car, then to the fuse box and starter. It is protected by conduit, but under the car it's easy to identify.
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5470066
1. they start other cars fine so id assume they are right for my car ?? :happy:
2. replaced starter motors yesterday and still have same issue
3. where abouts is the relay for this? (im still a bit lost on how to bridge it etc :s)
4. more then likely !
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5470070
That's good news, but must be frustrating not knowing!!
oh man, you have no idea, completely doing my head in !!!
now im trying to decide if i go to drift school this weekend or book the car into boostworx to get some work done
probably gonna go with the 2nd option
https://www.sau.com.au/forums/topic/338332-r33-wont-start/#findComment-5479091
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
