i have a fairly new genuine r32 gtr front bar for sale, has a small crack and little out dent in it, have spoken to my panel beater about fixing it, can be easily fixed, he quoted me $80 to fix. i no longer need it as i pulled the front bar off my half cut and used that instead.
dont really want to sell lower lip but will for right price.
asking $240 for front bar and $350 for complete bar lip and mesh. open to offers as it just takes up space.located in hornsby area sydney. any info needed feel free to pm, call or sms on 0415040002 thanks phil
i will take more photos and better photos tomorrow
Edited by GTR32R
https://www.sau.com.au/forums/topic/338734-r32-gtr-front-bar-lip-and-mesh/
