hey guys,
car has developed a tinny rattling sound at idle. it seems to go away with throttle, and then as the revs drop it rattles again.
i got under the car and held one end of a screwdriver to everything i could think of, and the other to my ear - and i suspect it's related to the exhaust. it could be something simple like a loose heat shield or a stone caught behind a shield......but i'm also worried it could be something more sinister - like little bits of ceramic exhaust wheel bouncing around in front of the mesh on the cat converter.......
stock neo turbo has been running 11-12psi off the EBC.......is there any other way i can diagnose other than dropping the exhuast in front of the cat and seeing what comes out? its my first experience with a ceramic wheeled turbo, so any insight would be good!
for example, if the exhaust wheel does sh1t the bed, does it do it all at once, or will the blades break/chip off slowly.....? because the car is still boosting reasonably strong, only paranoia is making me question it....
cheers! Mat
Edited by SMOKEYC34
https://www.sau.com.au/forums/topic/339084-name-that-rattling-sound/
Easy fix
take off the cat,smash all the mesh shit out of it
replace all mufflers with just pipes
then wen the exhaust wheel finally snaps you can shoot it into the car behind you
that's my logic anyways,then you won't have to worry about it rattling wen it breaks
on a serious note,check the bolts on both ends of your cat,I know mine would always come loose
start the car and let it idle,wen you hear the rattle go to the back of your car and hold your foot against the rear muffler
if the rattle goes away then it's exhaust related,I had a grounding wire dangling onto my cat and the rattle was so f**ken annoying,so I just chopped the wire off.f**k knows wat it was from tho...?
Good luck mate
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
