Item Summary: s13 rolling shell custom blue set up for Rb great drift setup
Asking Price: $3200
Contact Info: Denise 0404052011
i have for sale an 1992 s13 silvia painted in a custom blue
Set up for a rb did have a rb25det in it and gearbox. Just buy motor and gearbox and u have a great drifter.
1.body . painted in custom blue 2pac with nismo body kit ,debadged, tinted windows,black bonnet, hicass and abs removed properly all new r33 clutch master and new brake master, new white work rims 18"
2.suspension. gab adjustable struts all round with very large gab sway bars front and rear nismo strut brace
3.interiour.retrimed s14 seats with blue highlights on dash and door trims , saas wheel auto meter taco and cobolt water temp
4.driveline. r32 k frame and mounts, locked diff , custom 1 peice 1000hp tail shaft
5.brakes. has r32 na front rotors and r33 gts front callipers with new pads all round brand new master cylinder and lines
has walbour fuel pump and mod plate already.
the front bar and bonnet is black but will supply the same colour paint.
https://www.sau.com.au/forums/topic/339510-nissan-s13-rolling-shell/
why cant you be in nsw :P
can you road trip a guy in sydney wants too
cant get pics up to big but here is a link to photos
http://www.boostcruising.com/forums/index....howtopic=623737
Edited by nischic
  • 4 weeks later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
