have for sale Xfoce Varex cannon muffler
3" inlet with flange and 4" tip
as new condition. no dents or scratches. comes will all connections and adjustable hanger and 2 remotes.
these retail for over $400 new +postage. im looking for $300 and will post anywhere in Aus if YOU pay for postage (shouldnt be anything more then $30)
ta
Ash
https://www.sau.com.au/forums/topic/339879-xforce-varex-cannon/
hasnt been on my car yet. i bought it but never installed it. but the car it came off had it fitted for about 2-3 months then seller went for a different set up.
so i assume the valve works 100%?
did u get to test it?
cheers
  • 1 month later...
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
