  • Replies 106
haha i can't exactly borrow them cause i intend to smoke the tyres off them! but im all set now anyway, pit lane garage too with jangles, gonna be great.
and gtr blondie i call everyone mate haha boy or girl
Pit lane hey! Score! I'll make sure to drop in and say hi. Too scared to put mine in :P
What's up with the GTR Damo ?
we think its gunna be ok, ever since the car was repaired the clutch fan hasnt been right, replaced it with a secondhand one and put a spacer there to clear the belts but... its still not running 100% true and we are slightly concerned about the water pump. I have tested it and cracked some decent speeds and some 6k launches but just not 100% happy, Im still taking her down :thumbsup:
yea right. a bloke i know mid last year had a brand new water pump fail after about 3 hours. the result was a fan throught a radiator and a very big repair bill. lckily the suplier of said faulty pump paid for a new water pump. new ally radiator and a thermo fan setup but i think the bloke was out of pocket for the labour.
take the fan off and run decent thermos. i know every one says they dont work but if you get AU falcon or twin VT commo fans they will definatly do the trick.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
