Powercruise
GODZILLA-GTR
 Share
  • Replies 106
powercruise is boganised and is boring as batshit (been to all 3 so far), i'll be fishing haha. BUT i hope everyone who enters/spectates has a jolly good time
maybe, but you get to take ur mates for a ride in your ride, participate against cars you wouldnt usually see in competitions and make what you can of it.
i particuly like the fact that you think its boring as bat shit but you have been to all 3. lol
ive been to all 3. driven at 1 out of 3. after the first one i voued never to go again unless i was driving. last year id already payed entry but the car wasnt ready so i went anyway. wont bother going again unless there is some car driving action to be had.
Ive entered each time and had 3 engines fail. So not entering this year as I want the engine to last so I can get some ks out of the car. lol
well, you know, ya just hope the next one is better hahah!
I have to admit, i actually enjoyed the first, I remember watching the off street drags and some (i've forgetten his name...) bloke in that silver 33 GTR targa spec racepace built monster simply trounced everything that went up against it - inlcuding whitler/darby's, whoevers purple carpri. 340kw's & stupid response and 8000rpm launches and man could he get it off the line! very good wheeler. since then, it just hasnt delivered for me I'm afraid.
I have never been to p/cruise. My RX2 13bt ran up 314kw a few days ago. Been a long time coming.
It has no rego but I hope I can enter! The 'oldgirl' has done a few laps around symonds in a past life!
Being a retired 2E clubcar, now toy it has been a slow ongoing passion over the last 4 or so years. I have only ran it at symons 2 times in the last 3 years on test days and broke a turbo each time. In the last 12 months I have worked hard and spent money on quality bits!!! I am vary happy with the power it made on the dyno but that was just to get a tune in it!!!! Next job is fitting a boost controller. I am wanting to have a test at symons and a run at the drags before christmas. 12yrs ago it ran a 64 sec on a carb around symons and 2yrs ago it ran 12.6 1/4 mile with a little to4. Hoping to inprove on both times!!!! Then have fun at power cruise if I am able to enter!! I love skids!!!!!
  • 1 month later...
Not enough time for RX2 test at symons and drags before christmas. I am in the process of setting up suspension and brakes up for powercruise as we talk (daylight hours, before to much beer!!) Very keen for some skids!!!!!!!!!!
May be a S6 RX7 in tow, smoken em as one can!!!! Show your rotor HP!!!! Happy boostn!
  • 4 weeks later...
 Share
    • Slimline sub on the rear parcel shelf is doable. Pioneer TS-WX140DA is only 70mm high.
    • People like Johnny Dose Bro might be laughing at my post because I accidentally added 100mm to my numbers. 350-355 is indeed the lower limit. 450 is off-road Skyline spec.
    • What is the "compromise" that you think will happen? Are you thinking that something will get damaged? The only things you have to be concerned about with spherical jointed suspension arms are; Arguments with the constabulary wrt their legality (they are likely to be illegal for road use without an engineering certificatation, and that may not be possible to obtain). A lot more NVH transmitted through to the passengers (which is hardly a concern for those with a preference for good handling, anyway). Greatly increased inspection and maintenance requirements (see above points, both).   It is extremely necessary to ask what car you are talking about. Your discussion on strut tops, for example, would be completely wrong for an R chassis, but be correct for an S chassis. R32s have specific problems that R33/4 do not have. Etc. I have hardened rubber bushes on upper rear control arms and traction rods. Adjustable length so as to be able to set both camber and bump steer. You cannot contemplate doing just the control arms and not the traction arms. And whatever bushing you have in one you should have in the other so that they have similar characteristics. Otherwise you can get increased oddness of behaviour as one bushing flexes and the other doesn't, changing the alignment between them. I have stock lower rear arms with urethane bushes. I may make changes here, these are are driven by the R32's geometry problems, so I won't discuss them here unless it proves necessary. I have spherical joints in the front caster rods. I have experienced absolutely no negatives and only positives from doing so. They are massively better than any other option. I have sphericals in the FUCAs, but this is driven largely by the (again) R32 specific problems with the motion of those arms. I just have to deal with the increased maintenance required. Given how much better the front end behaves with the sphericals in there.....I'd probably be tempted to go away from my preference (which is not to have sphericals on a road car, for 2 of the 3 reasons in the bulleted list above), just to gain those improvements. And so my preference for not using sphericals (in general) on a road car should be obvious. I use them judiciously, though, as required to solve particular problems.
    • Easiest way to know is to break out the multimeter and measure it when cold, then measure all the resistances again once it gets hot enough to misfire. Both the original ignitor and the J Replace version. Factory service manual will have the spec for the terminal measurements.
    • Yes that sounds right. Cars currently in the shop for the engine work. Will need to remeasure .. but yes I think I must be targeting 45cm from fender.
