not sure of the exact specs denham
but its got a pretty huge ex wheel and housing on it
on my mates sr20 he runs 26psi but his has a smaller housing and wheel on the back - makes bout 300rwkw
i know that there r other turbos out there that can make that power at lower boost levels - but when ur paying 900 for a brand new t04 what am i to whinge :P
no its chromed its all a bit dirty at the moment and not quite finished but its working out well so far boost response is alot stronger and im having heaps of fun with the external wastegate pipe and pedestrians. the gf rekons it sounds like its goin to hurt someone or sumthing
here she is all bolted back in place.. car goes as well now as it did before on 13psi now only using 9psi so im happy tune up will be soon ill keep you all posted.
Did u manage to hook the 2 springs onto the clips with your xtr thermal blanket?
I am having a bit of a problem getting my to clip on
Hi guys, a lot of people look at the other upgrades (cams, porting, manifold etc), on a turbo car, as a way of increasing the maximum power at one particular rpm point. That's not what I do it for, I actually use these other items to increase the average power over the used rpm range. I also use them to reduce the amount of boost I run to achieve the same maximum power, this increases the responsiveness of the engine as well.
A comparison;
1. I have an RB engine that needs 1.6 bar to achieve 600 bhp with standard cams, ports, lowered compression ratio (thick head gasket) and a combined dump. It has 360 bhp average power (4,000 rpm to 7,500 rpm).
2. The same RB engine that only needs 1.3 bar to achieve 600 bhp with 264 cams, ported, manifolds matched, standard compression ratio and a split dump. It has 440 bhp average power (4,000 rpm to 7,500 rpm).
Some people would say that I wasted my money on the cams, porting, split dump etc since I still only have 600 bhp. I would of course reply yes, but I have a 22% increase in average power, so the car will be substantially faster. Plus the response will be also dramatically improved by the enhanced breathing, with better off boost performance and faster to build boost.
Hope that makes sense.
sure does
ur peak power stays the same but ur power over the rev range to acheive that peak power increases
torque would increase over that rev range to achieve a faster car lower down, resulting in a faster car at higher speeds
correct?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
