yeah its a good point you make,Here is a couple anyway, I dunno how you guys post them the way you do :)
John, upload your photos to Photobucket or Flickr or some other photo hosting website (even Photoshop has their own service), and then link them here. :D
That's one great photo Kory!
What are the chances of getting my GTR in front of that back drop?
Brian, as Kory said, that spot is gonna be hard for setting up any cars there.
Link: Mrs Macquarie's Chair
  • Replies 244
Posted Images
Will drop you a pm some time, about to change turbo set up on the car and need to put a baby seat in the back and drive the around more. Im lucky if i done over 1500km in the last year in the car.
No drama's mate :) Just let me know when your ready!
John - Seriously no point in doing a photoshop course. There is sooooooooo many tutorials out there on the net. Host your photos on flickr. Photobucket is restricted at too many places to view during the day at workplaces etc... so your photos will just get skimmed past (good point here!).
Research things regarding white balance correction, levels, curves, sharpening and layer masks and then after that, it's up to you what you want to do with the photo :) There are many ways to do the same thing, some are better, some are worse or are much more time consuming.
Keep it up mate! You should be proud of your photos for how long you have been taking photos. Night photography is one of the hardest parts of photography.
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
