hey guys n gals im puttin my turbo up for sale its a garrett 3582r aka the 3540 got a .82 rear housing its external wastegate only done 1000kms on 10psi perfect condition
reasong for selling is its a bit big for the power i want im only after 260-270rwkw and would like something pretty responsive not sure which way im leaning towards either a r33 highflow or a hypergear tr43 g3 love to kno how responsive they are im also keen on a swap if u have something that will achieve these results
looking for 1100 ono comes with turbo and oil in and oil return line chuck me some offers guys taking of the car tomorrow if u have something decent make me a deal im easy goin we can work something out cheers
https://www.sau.com.au/forums/topic/341490-gt3582r-aka-3540/
Hi, location please
cheers
Alex 0433878905
JAK Motorworks
campbellfield 3061
buy yourself a 0.63A/R turbine housing, that will drop your hp to a level more suited for your needs and will also bring boost on about a 1000rpm before. it will still hold boost to redline tho, so no loss there. i did the opposite, went from a .63 to .82. everything else bolted up the same
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
