Hey fellas
I know I'm gonna regret this but I'm selling my Genuine AME Modelarts
I highly doubt anyone will find another set like these
I have owned these rims for almost 8 years now.
20x8" fronts and 20x12" rear
the wheels started out as 20x8s all round then I got a set of dishes custom made overseas
I have never seen or head of a set of AMEs in this size or offset
Theres were an 8K set of wheels when new plus the money i spent on em to widen the rears
I got an offer of 6k when I had them on my skyline but I wasn't prepared to sell them back then
I have no car to put em on now and I really want to get cracking on my merc project so its time to let em go
They have a PCD of 5x114.3 at the moment but i can have em made to fit anything.
Im taking offers at the moment so if your interested PM me.
Ideally id like something close to 6k but these kind of wheels aren't for everyone so if anyone is seriously interested PM me and we can go from there
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
