Hey all.
Been driving my sv21 granmy for the past 4 years and think it's about time to hop into something with just a little more power.
So been searching and eying off cars for a while now and narrowed it down to an R33 GT-ST or 2.5L TT/T soarer as both are in my price range and have plenty of power.
Still trying to decide which one to go for but I guess I'll have to test drive to really see which one I prefer.
Any hints or pointers to pick out a good conditioned car would be appreciated.
Cheers
https://www.sau.com.au/forums/topic/341773-hey-from-the-gold-coast/
Drive a Toyota Chaser as well, there are really nice cars and if you can afford the Manual, you will not be disappointed. they got 2.5 T VVTI engine, the one you will find in Soarer as well
also 2001 Nissan Skyline V35 Sedan might be worth a look
most soarers are priced under $10k these days, few to be had under $6k.
so far found one nice '97 VVT-i Turbo for $8.5k under 90k on the clock.
There's a nice 33 auto on carsales atm for $7.5, waiting for holidays before purchasing though.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
