1992 r32 4door
IMPORTED THREW ADELAIDE JAP NOT QUIT 2 YEARS AGO
-120,000 klms
-custom fresh turbo from ATS ( using r34 op6 )
-greedy fmic,mostly truck clamps
-Earls oil cooler an relocator
-dose pipe, afm relocated
-am screamer
-strate pipe with 1 ressy SOUNDS TUFF
-power fc an controller
-hks evc5
-adjustable cam gears inlet an ex
-walbro pump
-heavy duty extreme clutch (do have brand new 6puck waiting go in)
-brand new headgasket, belts and lines
SUSPENSION
-npg coils in front
-isc in rear
-whiteline front adj sway,extra bracing
-whiteline rear adj sway, extra bracing
-GTR strut brace front
-strut brace rear
-brake stopper
-33 lcas
-hicas lock
-kkr camber
-kkr castor
INTERIOR
-kenwood mp3
-kenwood speaker fr an rear
-greddy indiglo boost gauge
-shift light
_FREEZING COLD AIR_
EXTERIOR
-weathershields
-custom side skirts
-pods
-custom front bar
-roof wing
( has drift scar from white refector passenger rear quarter)quoted $800 to metal finish an paint !
- an custom dents above each pumped guard
-will come with 33 stockys
DEFECTED FOR TRACK AND REAR TOO LOW, 18+22/10'S ALL ROUND track was out by 10mm and rear too low by 20mm
MAKE AN AWESOME TRACK WHORE :P
JUST SERVICED WITH ALL FLUIDS AN EXPENSIVE OILS , oil changed monthly til now
10k firm or will remove some goodness an negotiate, will swap for stockish S14 / r6 or maybe daily an coin my way
Pm for further details, if want more pics come see the car in person or will mms them.
located Sellicks Beach
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
