Hi everyone,
I'm selling my 2005 Silver 250GT V35 sedan and done 50,000kms.
Features:
Privacy Glass on rear of car
Clear Side indicators
Cruise Control
Dual Airbags
Dual Climate control air conditioning
2xIKeys
Xenon automatic-on/off headlights
Factory 17" wheels
Rear Lip Spoiler
Reverse Parking Sensors
Earth Kit
Momo Silver Gear Knob
LCD TV screen and aftermarket headunit
Sports tiptronic mode for manual shifting
Still under premium extended warranty, 2.5 yrs left
Full service history in Australia
After $19,500
This car has been well maintained and has been serviced every 5,000 km. It is garaged every night.
The VQ25DD 2.5 litre Neo direct injection engine provides excellent sporty performance combined
with a smooth comfortable luxury ride.
Car is in Melbourne and any queries please contact via PM.
Here are the photos:
https://www.sau.com.au/forums/topic/343399-melb-2005-skyline-v35-sedan/
Thanks hopefully we can sells the V35!
Anyway here are some updates:
Bosch Aerotwin Wiper Blades
Nissan Floor Mats
Nismo Sports Pedal Covers
Pioneer Mp3 / CD Player
SxExCx Custom Grounding Kit
Skyline Trunk Side Separator
Also the car had been detailed by Final Inspection on August and come with the V35 Skyline Handbook with Touch up pen.
Oh yer car just over 50k kms and had a service done too.
Here are some more photos:
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
