Solid Teak Wood Dining Table 6 Chairs also extends to allow for more chairs or extra space. Excellent condition no scratches or fading areas anywhere always covered and well taken care of. However there is one chip (size of a 5cent piece) on one of the chairs as pictured below. The seats have various flower patterns on them and all seats are covered with protective plastic they look brand new no tears, stains etc...
Standard Size:
L: 165 (1.65m) x W: 110 (1.10m)
Extended:
L: 210 (2.10m) x W: 110 (1.10m)
Selling due to downsizing the table its a little to big and is currently taking up a lot of room.
Price is $550 ono please call 0406 822 338 for any questions or details you might want to discuss or shoot me a PM. Located in Melbourne
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
