El Xr6. Ported and polished head, big cam, valve springs, CAPA chip, pacemaker 4480 comp headers, full 2.5" exhaust. Awesome condition. Green in colour. Lowered profesionally. 19" FPV typhoon wheels with good tread. Doesn't sound like a typical ford. Sounds awesome, is quick. 161kw at the wheels. 5 speed manual. 130,000 original k's. Trip computer. 3" mandrel bent intake pipe with pod. I have a bigger throttle body brand new i have not yet attatched. All work done by heinrich performance and tuning. Is an awesome car. Just want something turbo's preferably skyline. Let us know what you got anyways, dont hesitate to contact on 0432 806 081, or send us a email. Looking to do something pretty soon. Cheers.
https://www.sau.com.au/forums/topic/343690-el-xr6-worked-161rwkw-sa/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
