Hi People,
All items located in Sydney - Epping.
Post ok if buyer organises OR can deliver certain items
Contact any time -
PM on here
Cris - 0403491735 Call or sms
Adrian - 0413208919 Call or sms
Photos on request - inspection welcome any time!
WE NEED ALL OF THIS GONE! NO REASONABLE OFFER REFUSED!!!
Willing to trade for items of interest including (cash either way depending on item and condition) -
Front facing RB25DET intake manifold.
Bride Seat + Rails.
R32 Half/Full Cage.
Wheels of interest.
Genuine GTR front bar cover.
RB25DE SII
Complete engine in great running cond.
Came off a Stagea.
Comes with manual R33 ser2 ECU.
Comes with front AWD diff - You can change to RWD very easily and sell the FWD diff.
Never skipped a beat, ever.
Only top fluids used.
Regularly serviced.
Did a compression test before removed and showed to be very healthy engine.
$700 ONO
RB20DET Head
Complete head, has a small weld on one side so selling as is for cams, cam gears etc
Must go, need the space!!!!
$150 ONO
R32 GTS4 Front Diff
Comes complete with sump assembly and diff housing.
4:3 ratio!! Perfect for lowering your GTR diff ratio
Working perfect when removed from car.
Barely used as car has been often run in RWD mode.
$500 ONO – MUST GO!!
RB25DET Block
Needs oversized pistons - been bored out
Bores in good condition, no scoring etc.
Comes with everything except pistons.
$100 ONO – NO REASONABLE OFFER REFUSED!
R32 GTS4 Manual Gearbox
Reasonable condition.
Comes complete with transfer case
2nd gear has usual R32 uneasiness to shift into when cold only.
4th gear had a little bit of a crunch when shifting into at high RPM, otherwise fine in normal conditions
$400 ONO
R32 5 Point Roll Cage
Alloy.
Great fit.
Very light
Painted black
$300 ONO
R32 4door aftermarket (fibreglass) rear bar
Unpainted.
Small chip on corner edge near wheel arch.
$200 ONO
R34 Front Cradle + Rack
Very Good condition
Offers
R32 Motorised Lower Lip
Motorised lip that lowers above a certin speed.
Or you can lock it down to make your car look more low, and raise it when need be, driveway, speed bump etc.
Comes with everything you need, motors, lip etc.
Offers - NEEDS TO GO!
HKS Style SSQ BOV
In Fully hektic chrome.
$50 ONO
GTR Fuel Pump
Comes complete with sender and everything. Bolt in job
$75 ONO
GTR R32 Intercooler
Slight damage to a couple of fins
No leaks
Will hold boost no probs
No restriction to airflow
Offers - MUST GO!!!
R33 Airbox
Complete
RB25DET
$200 ONO
GTR R32 front drive shaft - From transfer case to front diff
x2
Worked fine
$50 ONO
Stock GTST Fuel pump
Complete.
Worked fine.
Direct bolt in.
With sender
$20 ONO
Stock Turbo exhaust manifold
$20
Clutch Fan with clutch coupling and R32 fan
Worked fine
$80 ONO
Air Conditioning Compressor
Worked fine
$80 ONO
Space Saver Wheel
Heaps of tread
Un used.
Brand spankers
ANY offer
Alternator
Perfect working condition
$50
Attessa pump
Worked fine.
$50 ONO
R32 GTST/GTS4 fuel tank
+ Tank straps
Been slightly pushed in but NO LEAKS
$20 or a case of beer. - Preferably not a $20 case of beer :blush:
I'm interested in the space saver wheel.... I'll give you $50 for it plus postage.
PM me if you're interested.
Hey Cris
I might ring you about this tomorrow, but do you have your old GTS4 4wd tailshaft? As I assume your running a rwd tailshaft now? I am in dire need of one.
thanks
  • 3 weeks later...
hey there i was woundering if u hav any pics of the R32 Motorised Lower Lip at all and how much would it b to post it to adelaide
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
