I have a brand new EMS 8860 ECU for sale. This was meant for a project car and was never used. It acually has a base map installed for a VQ30DET engine but all different maps are available from the EMS website to download. Its as easy as deciding what engine you want a base map for and loading it onto the ECU, either that or get the complete tune done by your tuner. This ECU has the upgraded map sensor and will take a fast reading wide band O2 sensor.
From the EMS Website:
The Motorsport Series comprises of 3 state of the art Engine Management Computers. The 4860, 6860 and 8860. These ECUs are designed and built on the many years of experience of the EMS engineers. Like all EMS products these are fully upgradeable as new software features are released.
One ECU fits all. There is no need to send your ECU back for re-programming when you want to fit it to a different engine. The same ECU can be re-programmed by the user to suit almost any engine.
Key Features
Dual Tuning Maps. All Motorsport ECUs can have 2 engine tunes. The second tune can be activated via any one of the digital inputs.
Engine Protection System. All Motorsport ECUs have a configurable engine protection system that can minimize and in most cases prevent serious engine damage.
8 User Definable outputs. 4 outputs can be programmed as digital or PWM and the other 4 as digital only. These can be used for controlling thermo fans, Idle controls, movable cams, fuel pumps, Boost Control, Variable water spray, etc.
4, 6 or 8 Sequential Injector outputs
4, 6, or 8 Sequential Ignition outputs (Coil-on-Plug)
7 Dedicated Analog inputs Water Temp, Air Temp, Lambda 1, Lambda 2, Throttle position, Manifold pressure and Battery volts.
9 User Definable Analog inputs for normal temp sensors, exhaust temperature sensors, Suspension movement sensors, G sensors, air flow meters, etc.
5 User Definable Digital inputs for Nitrous control, Two step rev limiter, air conditioner idle-up, etc
Stepper motor control. All Motorsport series ECUs have a dedicated 4 wire stepper motor controller which can be used to control 4 and 6 wire stepper motors.
Dual Adjustable RPM and load points for fuel and ignition maps. The Motorsport series offers 48 RPM points with a 1 RPM resolution and 32 load points with a 0.1 percent resolution per map. You can define any number of RPM and Load positions you require to tune with. This provides non compromised tuning ability. The advanced micro code will perform a 3 dimensional interpolation between all load points.
Multiple Load Sensors. All ECUs in the Motorsport Series can be programmed to use 2 load sensors in cases where the engine may have 2 load measuring sensors such as 2 air-flow meters.
Connects to most sensors. This means that you can use your existing sensors with the Motorsport Series.
Advanced trigger circuitry. Automatically filters trigger inputs for noise ensuring that the trigger signal is always 100% accurate. This combined with the advanced auto signal tracking and true zero crossing detection with magnetic sensors always provides accurate timing at all engine speeds.
Advanced Micro Code EMS have put great effort in programming their micro code to ensure it stays in exact synchronization with the engine. This minimizes the risk of misfired and lean strokes therefore increasing engine life and providing more power. The system also performs a 3 dimensional interpolation between load points to ensure that your engine is getting what you tuned it to receive.
View Specification Sheet (PDF)
Key Features
The only thing i don't have is the original loom. A complete new loom can be purchased from EMS for $150.
$1200
https://www.sau.com.au/forums/topic/344998-ems8860-ecu-brand-new/
