Well i spun a bearing and f**k 1 rod and its got a 22mm piston pin and spool don't make them with a 22mm piston pin anymore so i don 't really want to buy another set of rods and pistons so i wondering maybe i could get a second hand one to get me going again. Cause the motor has only done a few thousand k's. So if anyone could help would be sweet. Cheers
