Ummmmmmmmm
Genuine Works VS-TX 19x9+37 (front) 19x10+36 (rear) No tyres.
I bought these new from japan around 12 months ago so i also have the Work boxes they came in.
They are in "as new condition" (as the pics indicate)
****ASKING $3,100****
These are the latest VS design in the Work range & they have the Work serial number plated on the outer edge of each rim.
Beautifull rims with very nice dish on the rear!
These will clear big brakes on the front so brembos,alcons,surpa brakes etc fit behind these nicely.
I had them on my soarer and what an improvment they made made to the looks.
As stated in the title,will fit Most skylines including r32,r33,r34,v35.Soarer,supra,aristo and what eva else these offsets fit....
NEW PRICE FOR EACH RIM IS $1390X4=$5560 SO PLZ KEEP ANY NEGATIVE COMMENTS TO YOURSELF!
I can ship Australia wide via courier @ your expence (around $100-$120 Australia wide) or u can pick up in southside Brisbane.
Prefer phone enquiries rather than pm's !!
PLENTY OF PICS ATTACHED SO U CAN SEE EM FROM EVERY ANGLE.
PHONE-0414-729-004
  • Replies 40
Have a look at these...great looking wheels and only $2600+ postage Australia wide which wouldnt be any more than $120????
Cheepiest 19inch Works that look as good as this..
0414-729-004
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
